Electrics
Electrics
Hi after some help my 06 glide ultra classic has some gremlins
1 I keep blowing the fuse on my running lights, obvious a short but using an Ohms meter I can't find any change in the resistence of the wiring
2 After hunting this prob i now find that although I have ignition lights the management light won't come on and there is nothing on the starter button,the fuel pump did run but now doesn't nor does the headlight work, i suspect this is down to a low battery Ive got this on charge to see.Any thoughts out there ta
I don;t have a wiring diagram for your bike.
does this fuse only pop when the spot light switch is "On" ?
if yes-turn the switch to off & shake the bike ...smack the tyres with a cricket bat and see if the fuse holds...if it does than all good.
if it doesn;t check that the front fender tip light wiring isn't shorting on the fender- I don't know if that is on the same fused circuit
if the fuse material is "spattered" and carbon traces are inside the fuse- then it is a short...if the material has sagged and parted, that is an overload
check the spot bulbs that the bulbs haven't shorted...and trace the wires from teh spots back to teh switch
mike
mike
