clatter/oil pressure
Your 2011 Street Gilde has a wet sump oil pan, it is not dry sump. Your bike holds approx. 3 1/2 qts of oil. You should have gotten 3 qts out of the oil pan when you removed the plug. Verify with the owners manual or a you tube clip which hole you should put the oil in. Verify both the oil and trans dip stick levels.
sundancewind
Oil Archive (no new posts)
08-02-2008 11:22 PM
