Testing regulator, need help
Old 08-09-2018 | 06:55 PM
toryhardin92's Avatar
toryhardin92
Originally Posted by woodthumb2
yep... another vote for the regulator... change it first and go oem in my opinion... my old would work fine one day and not the next... are you seeing high or low voltage codes ?
either could be signs of regulator. I just purchased a MSV? Regulator for my 16 FXDB and it is working great. 14.4 on idle and 14.6 at 2000 rpm. My old regulator would not move from 14.15. Kinda forgot which bike you posted about, but if is a newer dyna they are damn sensitive to low voltage. canbus......
Old 09-15-2019 | 06:24 PM
vicsponjr's Avatar
vicsponjr
Low voltage. I took it straight back to the garage the first time it threw the code. I have been starting it to check things and it keeps dropping to low voltage and then back up. I haven't seen a high voltage yet, just low and normal. I am going to replace the regulator and see what happens. Hopefully its not the stator.
tundra
EVO
08-28-2012 06:41 PM
t059736
05-21-2012 09:15 AM
04nightrain
03-17-2011 06:15 PM
WRAITH
11-22-2010 01:04 PM
schlof
12-16-2005 05:35 PM
Quick Reply: Testing regulator, need help
