Head Pipe questions
The catalytic converter is a box designed to contain the converter media and flow characteristics are ok at best with the media still inside. Remove the media and you change flow and the box with corners may not flow as well as original, not as good as aftermarket. Aftermarket headpipes are designed to enhance flow and reduce heat with removal of the cat
According to a dyno run that used to be posted on the Fuel Moto site the difference between a performance head pipe and a stock pipe without a cat is about 1.8 HP. Not enough to make any difference.
If you are just changing mufflers, AC, and possibly installing cams, you will not gain enough with a performance head pipe to justify the 500 cost. Installing heads, bigger jugs, etc. then you will benefit from the head pipe.
Know that mufflers, AC and no cat will require some sort of tuner.
Bill
Bill
As others have mentioned, once the cat is out it will defenetly run better and hotter (leaner), you need a tuner. At that point the question becomes who is doing the tuning and what do they recommend. Many discussions on the sensor crosstalk when the cat is removed. If you want to ring out every last bit of power you need a quality head pipe. Fulsac makes a sport pipe which is a stock head pipe with a modified cat chamber, and they have an exchange program that is reasonable. I use it no complaints, probably leaving some power on the table, but not enough to worry about. Talk to your shop what they use for tuners, or if you are going to do it yourself do some more reading. Think of future mods so the tuner, the head pipe will suit your needs.
Bill
Bill
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
