Air cleaner question
I've been told that the round air cleaner off of the `14's & `15's
will fit my `12 Limited.I have a K&N in the stock `12 housing.My
question is if I change to the round air cleaner with a K&N filter
since it has the scoop & the front opening will it flow any more
air than my football cover?
the complete stock air cleaner off a 14+ will fit on your '12 throttle body.
and will flow about 15% more than the stock '12 air cleaner with the stock paper air filter.
you can check with K&N whether your filter would fit in the new housing
if you just want a high flow air cleaner the ness big sucker is under $120 on ebay from easternpc.
it uses the football cover ( which will hide the servo motor plug and wiring)
and comes with an oiled, washable filter similar to the K&N
mike
mike
