coasting downhill in neutral
I find it difficult to find neutral at speed. That and I just don't have any desire to coast with my engine off. Never know when you might need the engine.
All that clanking of gears when you shift down to neutral and again when you start the motor at speed and want to engage the correct gear.
You would think some folks who argue about downshifting and using the engine to brake would have a few comments about this one.
On a motorcycle you can only control two things:
Speed and direction
Coasting in neutral takes away 50% of one of the two things you can control.
Is it as dangerous as pimp slapping a 1%er and calling him a *****? Probably not. But as stupid as people are these days I never willingly give up an advantage when riding on two wheels.
Speed and direction
The motor oil not only lubricates the moving parts ( reducing heat generated by friction) but carries heat away from the hottest parts of the motor to be dispersed to the air.
The primary and transmission each have fluid in them and are "splash oiled"- the moving parts fling oil around.
even with the clutch pulled in, the primary chain is moving in the case and slinging oil around
The tranny in N, the tranny shafts are also moving, the mainshaft driven by the drive belt.
and neither the primary or the tranny are under load at that time
oiling shouldn;t be a concern
mike
Amazing how many things you can hear when coasting down a hill with the motor off. Tire noise off the different road surfaces, your brakes engaging the pucks, the wind in your helmet, the sounds in the bushes around you. Pretty interesting stuff actually.
Can't imagine it hurting anything in the bike or transmission as everything is just free wheeling.
Illegal?
It's funny, but I was just reading a book titled "The Motorcyclist's Legal Handbook"...2011 by Pat Hahn He wrote that while researching laws in every state, he encountered over 3 dozen times, a law on the books that coasting on a motorcycle was NOT allowed!!!!
Oh thank you government for writing such laws to protect us! I feel so much better now!
