Cam Chain Shoe Replacement
So I am thinking its about time to replace the Cam Shoes again -- 50,000 miles on the second set. -- I am sure many will say to go to the hydraulic tensioner upgrade -- but with 115,000 on the bike -- not sure I want to do that expense.
So I am thinking changing just the shoes -- the chain should be fine, but my real question, do I need to change the oil pump? -- It has 115,000 on it also as I did not change the pump when I changed the shoes at 52,000. Will also change the lifters.
What company parts should I go with -- not sure how many miles I will keep the bike as I will probably sell it when I retire. So I am thinking expense to value ratio also.
The question was asked about my compensator -- it is the original.
My main goal in this maintenance is to keep the price as low as possible -- I will look at the upgraded hydraulics as compared to just shoes and possibly oil pump.
I plan on doing this during Christmas time -- when the weather should be the worse -- I am also 50 miles from the closest dealers both indy and Moco -- so am trying to round up just the needed parts and have to make a trip for extra.
Another option would be to go with a reman engine at the cost of around 5,000 -- but then again -- I may not keep the bike for that many miles since it is my daily rider and will probably sell after retirement
115,000 miles? Obviously its working well! As bigheadted said the oil pump specs are in the manual. The wear area I have noticed on oil pumps is any scoring on the back of the cam plate where the oil pump gears spin. If thats not scored you are probably good to go. I would probably go with the Cyco shoes. But you won't know until you pull it apart. Cyco has an installation tool and guide that looks pretty slick. What I don't like about changing the shoes is pulling the rockers and cams just to get to the shoe on the back of the cam plate.
[QUOTE=OwnerOfHarriet;14323963]The question was asked about my compensator -- it is the original.
Another option would be to go with a reman engine at the cost of around 5,000 -- but then again -- I may not keep the bike for that many miles since it is my daily rider and will probably sell after retirement[/QUOTE
Then just put in the shoes
