Frustrated w/ newly developed left tacking
Dilemma: my bike at any speed tracks to the left :-(
I replaced all 6 wheel bearings, new ebc double H pads, new MC2's w/ ride-on.
I'm proud of my work but have a bad left tracking.
Interesting thing is I adjusted used the 10lb tool to adjust the belt tension but after the 10 mile ride to even out the ride-on the belt is too tight. So I will remove the right side pipe and adjust the belt again and resolve that issue and see if during this process I resolve the left tracking.
If that fails, I will check the fall away on the front. I've also read in here that someone had a right side fork pinch bolt that had broken which allowed the right side fork to drop enough to cause his issue.
It is frustrating.
Oh for what it is worth, there is nothing in either bag, no wallet issue, nothing attached to the handle bars and my bike tracked neutral before my work mentioned above.
Will post status as I try to eliminate the issue with each corrective action.
Any insight?
It is frustrating.
Any insight?
I'm thinking you didn't get the rear wheel straight. Jack up the bike and spin the rear wheel while looking at the track of the belt on the rear sprocket. Adjust wheel until the belt is tracking as close to center between the two sides of the sprocket as you can while keeping the belt tension correct. When centered, tighten everything and go for a putt.at least that is how I do it and both mike bikes go dead straight. This how I fixed the same problem, for what it's worth!
don;t overlook weight in the saddlebags- make sure you are balanced left/right.
2 x 8' florescent light tubes are handy for alignment- place on each side of teh rear tire extending forward- distance from tube to front tire should be same on each side
3.) when pushed forwards the belt will track to the inside of the pulley...when pushed backwards, to the outside of the pulley.
mike
mike
That being said, I would recheck the alignment as others have suggested...
Big thanks Mike!
f'd with it long enough to your number 3 suggestion (as it seemed easiest to do) and BAM tracks neutral now!
Thanks you.
Unfortunately, while under the bike, I discovered what I feared most by virtue of sound while riding... My IPB ***** the bed. I know the sound and lumpy movement on the belt is coming from the front sprocket.
Looks like I will be pulling the primary. F me.
Thanks you.
Spec36
04-02-2018 07:11 PM
