The fuel gauge and the Fuel Range Function on my 2010 Road Glide crapped out in the middle of today's ride. (Gauge is on E, and the Fuel Range reads ---). My first thought was a blown fuse, but the other gauges are working fine and I believe the Service Manual indicates that they are all on one fuse.
If this is the case, is it likely the sending unit? Anyone else have this happen?
Turns out that the problem was the fuel gauge connector inside the fairing became disconnected, resulting in the fuel gauge malfunction. Rerouted the wire so it wasn't so tight and zip tied it. Problem solved.
