Slip On Exhaust Problem
Greetings!
I have an issue with my Screaming Eagle slip on exhaust pipes that is very frustrating, and quite frankly very confusing. My bike is a 2011 Ultra Limited.
This morning I removed my SE Street Cannons, and attempted to replace them with the slip on pipes I had on previously: SE Diffusion Disc pipes (part #80847-10).
The HD dealership removed the SE Diffusion Disc pipes about 18 months ago, boxed them up, and installed the Street Cannons. The boxed up pipes they removed have been sitting in my garage until this morning when I tried to install them.
I removed the Street Cannons easily, and tried to slip on the SE Diffusion Disc pipes. As with every other exhaust pipe I have ever installed, the right side pipe (and sometimes left as well) has an indentation to accommodate the right side axle nut protruding outward. However, neither of the Diffusion Disc pipes had this indentation. So...I guessed that perhaps one of the pipes was narrower than the other. I was wrong...they are identical.
I attempted to install each pipe on the right side, but they each contacted the axle nut. I can't see how they would slip on without the indentation.
SO...either I am totally inept (it's possible, but I have removed/installed countless pipes over the years), or the dealership mixed my pipes up with others they may have had, and gave me two left pipes that don't have the indentation.
Hopefully someone out there has these pipes and can tell me if there is, in fact, an indentation on the right side pipe...or can tell me what I am doing wrong.
Wanted to check here first before I go to the dealership and make some wild allegation that they will likely deny anyway.
Thanks in advance and best regards! A06
P.S. I also posted this in Tech Tips, but there doesn't seem to be much action over there.
Greetings!
Hopefully someone out there has these pipes and can tell me if there is, in fact, and indentation on the right side pipe...or can tell me what I am doing wrong.
Wish I could do more to help you A06.
It does sound like they may have given you 2 left side pipes.
If it is as you say, that you've tried all ways to make them fit, it's got to be the reason.
Good luck in getting answers from the dealer.
Bring the evidence, in the box, with their sealing tape, like it had been for 18 months.
Cheers........
Cheers........
Cheers........
Thanks again!
