HELP!!!
RE: HELP!!!
If fuses are OK andyou've got a Service Manual, go into the wiring diagram for your model and see what color the two wiresfor the "stop/run" switch are. (It'll show at the Deutsch connector for the harness from the controls....six pins total, two to the switch in question.)
Seperate the Deutsch connectors and see if you have continuity across the two pins when the switch is in "run".I'm guessing thereisn't any.
If you don't have a manual I could go look to see.
CN
CN
RE: HELP!!!
ORIGINAL: Comfortably Numb
If fuses are OK and you've got a Service Manual, go into the wiring diagram for your model and see what color the two wires for the "stop/run" switch are. (It'll show at the Deutsch connector for the harness from the controls....six pins total, two to the switch in question.)
Seperate the Deutsch connectors and see if you have continuity across the two pins when the switch is in "run". I'm guessing there isn't any.
CN
CN
RE: HELP!!!
Ok...I'm guessing since you ran the harnesses outside the bars, you didn't end up removing the headlight nacelle, exposing the connectors on the ends of the hand control harnesses.
If you are sure your fuses are all OK, then you'll first have to see if you have power from the bike on theharness going tothe switch housing on throttle side.
This requires a multi-tester and pulling the nacelle off the bike to expose the Deutsch connector for the throttle side harness. (this connector joins the harness from the bike to the harness from the throttle-side switches....there's actually a pair of them, one for each side hand control. In your case the problem appears to be a throttle -side switch issue;power not getting there and back, to or from the bike...look in the manual so you know whatthe connectors look like)
The manual's wiring diagram will tell you the pins in the connector from the bike that mate up with the pins fromthe hand control harness "run" switch.
Testing for continuity will see whether or not there is a complete circuit out to the 'run' switch and back along the hand control harness when the switch is on. On the harness from the bike, there ought to be something like 12ish volts on one of the corresponding mating pins, since that will be what the 'run' switch is interrupting.
It's not as difficult as it may seem, provided you have a multi-tester and know how to use it.
There's not much to mess up on the hand control side other than pinching the wiring up at the switch housing when re-installing them on the bars. On the bike side, well, there's a chance you've blown a fuse. I'd spend a bit of time therefirst so you're not pulling the nacelle apart when you don't need to.
I will check back later when I get a chance.
CN
CN
