valve on shocks leaking??
08-03-2015, 08:26 AM
My question is if the shocks hold air with the hand pump attached but loses air when capped and sitting or riding.. dos this mean I have a faulty valve??? this is on a 2015 Limited
08-03-2015, 09:47 AM
Could be bad or just not seated all the way. Unscrew the valve, clean off the tip & install. When you let the air out, you will get some oil residue with it, its normal.
The PVC air lines are prone to leaking at the mutliple joints.
08-04-2015, 09:01 AM
valve leak
Swapped out cheap schrader with a American made one...difference is just better made,, see if this cures the leak issue
08-04-2015, 11:21 AM
Not under warranty any longer?
08-04-2015, 12:52 PM
Quote:
Originally Posted by
lionsm13
Plus One, Did you have the dealership check it out ???
08-04-2015, 01:09 PM
Mix up a little dish soap and water, spray over the tubing and valve and if they are leaking you will see air bubbles foaming at the leak.
albngore
03-20-2017 01:30 PM
chadk
09-17-2015 07:03 PM
Wabbit
07-09-2014 02:25 PM
albngore
01-16-2010 04:46 PM
IU_Booger
08-04-2005 11:50 AM
