Brake rotors
Old 08-04-2015 | 08:04 AM
prezflyr's Avatar
prezflyr
I also tried the dial indicator and cresent wrench. HD floaters and Lyndall pads did the trick.
Old 08-04-2015 | 08:10 AM
Cpl Ed's Avatar
Cpl Ed
Originally Posted by steelerdude1
My rear brake rotor needs replaced, as it is beyond min specs. I checked it out due to a worsening pulsing. I am solos starting fo feel a slight pulse up front. Even though the front rotors are better than min spec, I think I'm going to replace them as well.
Given that the HD floating rotors are only $16 ea more through boardtracker, I am considering going that route.
What are your thoughts on the floating rotors vs standard ones? Better, or is the difference not worth the couple more bucks the cost.
Also, is there something better than the HD floating rotors that don't cost an arm and a leg?
Pretty good article here on braking and standard vs. floating rotors:
http://www.carbibles.com/brake_bible.html. HTH
kitt90
03-16-2015 05:57 PM
JDSporty
02-11-2015 07:40 AM
RussH
04-16-2013 01:36 PM
OneBlackFly
10-26-2008 09:39 AM
lowleveldriver
09-07-2006 08:40 PM
Quick Reply: Brake rotors
