Front fork noise
Is it a rubber squeak like a wet athletic shoe on a tile floor or a metal on metal squeak? How many miles, has the fork oil ever been changed? Slim chance it could be the fender mounts flexing. Grab the fender and push it and pull it in the direction of tire rotation and the reverse. Turn the handle bar full one way and push the fender farther in that direction, then try the opposite direction. Don't be overly aggressive as the fender is pretty thin and can buckle or bend. Any squeak with any of these actions? If it is the fork seal O rings being dry there will be quite a bit of disassembly required to reach the inner fork (top) slide under the cow bell. A drop or 2 of fork oil on the upper fork piece, then run the fork in and out and that should lube the outer O ring. Wipe the inner slide dry so dust doesn't collect and "sand paper" the seal as the fork works. Then reassemble.
Perhaps louder pipes would be easier.
It's more of a wet athletic shoe sound than a metal on metal. After seeing this I did push/pull on the fender like you suggested. No noise.
Bike just hit 50K miles and I heard back from the sellers daughter. She said her father didn't think the fork oil had ever been changed.
Going to do an oil change and see in my manual it calls for 7.75 oz per fork. I don;t see anything on the size of fork seals?
Broken Leg Rider
08-06-2006 08:10 PM
Broken Leg Rider
08-01-2006 04:38 PM
