Pulley differences
Is that the only diff. I've seen both on ebay that look the same and the local dealer says they don't see the 37781-07 in their books but the bike needs a 40217-07. I thought harley would be a little more consistant on their part numbers, however, they are confusing me. By the way I have a 2007 flhp and the 37881-07 is tha one on it and the chrome is peeling off of the teeth.
37781-07 (casting)...FLT ("Touring"...your FLHP) is indicated
40374-07 (casting)...Dyna is indicated
Differences?...since they visually appear to be the very similar...1", 66T...there might be a subtle, but important difference...maybe in the Offset. If I had both pulleys, i would measure them.
I would stick to your casting# 37781-07 (40217-07 finalized part#) and all should go well
Wish I would have seen this sooner.... I have one on the shelf.
https://www.hdforums.com/forum/touri...ocket-f-s.html
I think you're due for a bump
Touring
70T 1.5" then 1.125" til 2006
66T 1" in 2007 with 6spd
66T 1" BOLT-ON Cush-Drive 2008 only
68T Integral Cush-Drive 2009-later
2008 Cush-Drive below
