Head pipe install advice/tricks?
Old 07-28-2015 | 02:08 PM
Dan.1977P's Avatar
Dan.1977P
Originally Posted by SBates08
KWaller unless your using a PC5 or other type of programmer that allows you to delete the O2 sensors your wasting your time installing an 09 header on your 2012 bike.
2010 Limited with some stuff
You can't just extend the O2 sensor wires? Seems it would be a pretty simple thing to do.
Old 07-28-2015 | 02:22 PM
SBates08's Avatar
SBates08
The O2 sensors for the 09 pipe are 18mm and are designed to take the heat close to the header opening. The 2010 and up use a 12mm sensor and isn't designed to take the heat.
Old 07-28-2015 | 02:40 PM
harleyguy5571's Avatar
harleyguy5571
Originally Posted by jt metal
It's tricky. Get, I think the back one on line up in the hole, watch the mount at the bottom and pull/rotate the front one in place. It will go. Took me time to figure it out.
I remember throwing the flange bolts in loosely just to hold the pipe from falling out.
Mine was a PIA too.
Old 07-28-2015 | 03:21 PM
Dan.1977P's Avatar
Dan.1977P
Thanks for the clarification. Would be pretty easy to have a shop weld a couple 12mm bungs in the right place if the OP is willing to do so.
Old 07-29-2015 | 10:37 AM
KWaller's Avatar
KWaller
Got it done... It was screwed up nuts and luckily only one bolt had been cross threaded.
The bungs are up high, near the ports and I took the O2 sensors off completely as I have a V&H fuel pack that takes care of that issue.
Happy to report that the pipes are installed and sound awesome. Could use some more volume, but V&H says that these are their quietest pipes for touring. However, I'm curious if I modified the baffles or removed them completely (V&H doesn't sell alternate baffles for the monster ovals), if this will really affect performance. I would like more volume, but if it's at a major loss of performance, I'll deal with the situation as is...
Thanks for all of your help to those who offered insight!
KW
Old 07-29-2015 | 10:54 AM
Coastal CVO's Avatar
Coastal CVO
If aligned properly you should have plenty of threads, I added the cones and installed double gaskets, one on each side of the cone and had plenty of thread once aligned.
Ended up with .025 exposed thread after nut was properly torqued.
blarg
03-11-2015 02:08 PM
2007z71
01-23-2013 10:29 PM
deepsea
08-23-2011 06:14 PM
A7X
08-27-2009 07:47 AM
Curlingace
Exhaust System Topics
04-04-2007 10:28 PM
Quick Reply: Head pipe install advice/tricks?
