starter relay location 2001 electra glide policee
Starter Relay Removal/Testing/Installation
Check the starter relay operation with an ohmmeter,
jumper wires and a fully charged 12-volt battery.
1. Remove the left side saddlebag as described in
Chapter Fourteen.
2. Remove the frame left side cover.
3. Carefully pull the fuse block assembly (Figure
14) from the frame mounting tabs.
4. Raise the top cover latches slightly and remove
the cover from the fuse blocks.
5. Pull straight up and remove the starter relay
(Figure 15) from the rear fuse block.
Chapter Fourteen.
