Tts is a pita
Try a different map.
Wow! I've got the TTS Master Tune on my 2010 Heritage and it's got to be responsible for at least half the performance increase I got out of my build. That said, you definitely need to understand the Delphi Fuel Injection/Ignition System and what it is attempting to do on a stock engine to know what you can, what you should (and what you probably shouldn't) do on a modified engine. The good news is that it's a really fairly sophisticated software mapping application . . . unfortunately, that can also be the bad news . . .
I suspect he doesn't really understand the HD system, the TTS programs, or tuning in general. Hence he, and many like him, have problems. That's why there's products that really don't do much...the shadetree wrench usually can't mess up things too badly.
Well thanks for assuming wrong tree.. I'm no master mechanic but I'm not some shade tree guy rigging **** up either.. I do all the work on all my friends bike, all my own cars.. Everything.. I'd be my own dentist if It didn't hurt too bad..Here's what got this mod started.. I have a 08 flhx simple stage 1 and pv, neighbor has a stage 1 08 fatboy, other neighbor has the cvo and his son n law has an 09 stock ultra.. Cvo guy says he's gonna best up us and one day he goes out and the stock ultra smokes his ***.. He can't have that so he buys his stage one and tts to compensate.. He also mentioned that his bike was cutting out and lugging like it was in limp mode untill he down shifted.. I never rode it more than a driveway away before I started the mods and when I got it all done I rode around the block without the tune to see what I did.. It did the same thing he described.. Come home add the tuner and it's the exact same issue.. I don't think it's a tuning issue at all.. I thibk something is wrong with his bike.. I had no prior knowledge of the tts or its features I did slot of reading last night and learned some extra stuff about it.. I found some pdfs that have a very helpful step by step to do their auto tune feature as well had info on fuel and acceleration tables.. The tts doesn't come with **** and every manual had to be downloaded.. Their how to tune pdf doesn't mention doing anything with cams first.. I'll figure it out eventually
"The TTS doesn't come with ****" because Steve Cole is continually upgrading features. This is why the first thing you should do is check for updates. The PDF manuals will be updated at the same time.
I would clean the TBW plug on the throttle body servo. Also if head pipes were changed, double check the sensors were installed in the correct bungs.
