Go to the dealer and have them show you a set of Heritage style bars. That is the only set I know of that will not require changing cables. That's what I did and they work for me as well.
I'm pretty sure the Heritage for RK is what the 2014+ RK's come with. The actual 09+ Heritage bars are an option (56569-09 if I recall). Similar height to Heritage for RK with different grip angle (don't need to be pulled back to level grips). I've seen guys run mini apes from Wild 1, Santee, etc., prob 10". The guys at Wild 1 should be able to direct you.
I went with the '09 Heritage bars and have been pretty happy with them, I like them better than Heritage for RK. But shorter guys will probably favor the latter. After some home remodel stuff I'll do some 14/16 apes myself.
wanna add bars to my 2015 King, anyone have an educated guess on the max height i can go without replacing cables? thx
Most aftermarket bars that claim a 10" rise, that are also cut for Throttle By Wire, will be a direct fit on a 2015 Road King. Be careful not get sucked in and buy "Touring Bars" thinking your Road King is a touring bike. Thought IT IS a touring bike, it uses standard style handle bars, NOT the bars designed to go on touring bikes with the batwing fairing. Those are a completely different handlebar with completely different bends required to clear the fairing.
