09 wheels fit 06?
Old 07-15-2015 | 12:27 PM
lizard86's Avatar
lizard86
Default 09 wheels fit 06?
I know they are different sizes but just curious if I can fit an 18" front wheel off an 09 onto the front of my 06 without any major mods.
Old 07-15-2015 | 12:40 PM
tfi racing's Avatar
tfi racing
Never been done before,oh wait,only several thousand times...
https://www.hdforums.com/forum/wheel...l-install.html
Old 07-15-2015 | 01:17 PM
touchdown's Avatar
touchdown
no 09 wheels turn the wrong way
Old 07-15-2015 | 01:47 PM
skratch's Avatar
skratch
just so you know, if you take hd stock wheel/tire combos and compare the actual sizes, everything from the 16'' to the 19'' cvo are all almost virtually the same overall diameter. the only thing that you have to worry about is the bearing/axle sizes, and the brakes, pre-brembo vs brembo.
Old 07-15-2015 | 02:59 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The 2006 has 1" bearings and the 09 ahs 25mm bearings. The simplest way to achieve this assuming the wheel is off a NON ABS bike is to buy an axle and spacers off a 2008 or newer bagger and install those with the 09 wheel. Yes, the 18 with a 130/70/18 tire will fit the front of your 06.
Old 07-15-2015 | 03:52 PM
lizard86's Avatar
lizard86
Thank you. I should have known better than not to use the search feature. Thank you for the simple explanation though.
Old 07-16-2015 | 10:38 AM
multihdrdr's Avatar
multihdrdr
Be prepared to move your '06 11.5" brake rotors over to the '09 wheel OR you'll have to upgrade your calipers to '08-later Brembos to use the 11.8" rotors that could have been still attached to the '09 wheel.
You also might want to replace those first version wheel bearings to later revision 9276A (from 9276) or equivalent if they haven't been done already.
Old 07-16-2015 | 12:42 PM
skratch's Avatar
skratch
thanks, i forgot about the brembo vs pre-brembo scenario. edited my post above to reflect this in case someone does a search in the future.
Old 07-18-2015 | 11:34 AM
lizard86's Avatar
lizard86
Thank you. This is the kind of response I was looking for. The little stuff that makes a huge difference.
Old 07-18-2015 | 11:35 AM
lizard86's Avatar
lizard86
I also heard 09 and up models use different spec blinker fluid. Is this true?
Quick Reply: 09 wheels fit 06?
