Oil level check
You are approaching the 5000 mile service and haven't compared a hot and cold level your self in that time? Check your level before you ride, then check after the ride and get the answer for YOUR machine. On an oil change with filter change 3 quarts is good. Ride the bike a mile or two and adjust the level as necessary if necessary, hot or cold as you prefer.
.................. who could argue against using a CALIBRATED torque wrench. If you do go mid range for insurance IMO.
I just snug them down myself. These plugs are very easy to strip and a PITA if you do.
09 FLHR Oil Change procedure
I usually take the 3 quarts and dump them into my 09 king when ready...
Then I open the 4th quart and fill the oil filter (KnN) ONCE to the bottom off the threads... All done, I start and warm for a SHORT time (one minute) check for any Leaks then Check the level on the dip-stick.. IF I add about 6/8 more ounces it is full when Checked HOT...
Now that is ON MY Bike...
signed....REDHEAD
ADDED: I also use 10w60 LiquiMoly...
signed....REDHEAD
Have done many hot/cold checks, just wanted to know if mid way on the dip stick was low, that's all. My first harley, and coming from sport bikes with a sight glass, the correct amount was at the full line with bike level. Just weird on harley's that if u fill to full line while hot it ends up spitting out the air cleaner, so want to make sure I don't overfill it and have that happen
Have checked my service manual many times and, although it says hot check should be at the top of the etching, I have seen a few posts where people had oil blow by out the filter and all over the side of the bike if filled to the top hot check mark
Midway on the stick cold before you ride should be perfect. Just to be sure you verify by checking it hot.
