Rear shock question
Yes you can add oil to the shocks. As they take a specifie amount I recomment that you take the fitting off and drain all the oil, then replace it with the measured amount. I used a plastic syringe designed for irrigating eyes. with this you can slowly injected the new oil into the shock. It is fork oil that you can buy at the dealer. I recommed going to a heavier weight oil, it helps the ride some.
Of course if you really want a recommendation then "throw away the POS OEM shocks and buy a set of coil over shocks, you will never regret it.
I just put the progressive 944's on my 2009 Ultra. Much better ride than I expected. Well worth the money. As far as putting in heavier oil I wouldn't recommend that. I tried it in my front forks and I was not happy at all with the results. The forks were too stiff and the wheel didn't stay in contact with the road over bumps the way that it should.
HDSAE60
10-05-2014 09:08 AM
heavymetalthunder
05-11-2012 08:03 PM
