Intermittent stalling and throwing codes
Old 07-10-2015, 10:54 AM
Hausguy's Avatar
Hausguy
Hausguy is offline
Default Intermittent stalling and throwing codes
Hoping someone can help with a mysterious problem. 2012 Ultra is stage 1 per sig line - running PV for over a year with no issues. A few months ago I get a brief stumble (fuel?) and then all is good for a few weeks. I don't think much of it.
It then happens again...then dies. I wait a minute and starts right up and runs fine. Code thrown then was P0118 (ET Sensor High). I manage to get it to the dealer to check out since I have extended warranty. I suspect the sensor but they diagnose and tell me it's the ECM and replace it.
Now I have the new ECM. Still occasionally get the same code in addition to two new ones (U1016, U1040 - loss of serial data to ECM).
I've ridden a few thousand miles since this problem started. It seems to happen more when the bike is hot.
Are these codes related? Thoughts?
Old 07-10-2015, 10:56 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Weavr99FLHT is offline
You have extended service plan, take to a dealer.
Sent from my iPhone using IB AutoGroup
Old 07-10-2015, 11:24 AM
smithbrl's Avatar
smithbrl
smithbrl is offline
I'm thinking there is an intermittent electrical connection or bad pins on the ECM connector.
I had issues similar to this including "loss of serial data" code. The dealership replaced pins on ECM connector and that fixed the problem.
Old 07-10-2015, 11:32 AM
Hausguy's Avatar
Hausguy
Hausguy is offline
They replaced the ECM. I'm still thinking sensor(s) but I can go a day or more of solid running with no issues...
Old 07-10-2015, 11:56 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
I would guess that they replaced the ecm because they don;t know for certain what the fault was.
when replacing the ecm they may have "renewed" poor pin connections.
so take it back- the fix wasn;t permanent.
you have a warranty put it to work.
if the dealer doesn't inspire confidence, try another shop
your best bet as the owner is do not direct them to do certain repairs, just give them all the info you can on codes and leave it to them. hopefully they'll do a comprehensive check and find an actual problem.
Old 07-10-2015, 12:29 PM
Hausguy's Avatar
Hausguy
Hausguy is offline
I have an appointment with a different shop but they're booked for a couple of weeks. I was hoping for possible things to try to troubleshoot on my own while I wait.
The first place wanted to dyno it for me, then they wanted to blame the Powervision (that my tune was possibly corrupted), which was flawless for over a year.
Old 09-02-2015, 05:15 PM
IHC67's Avatar
IHC67
IHC67 is offline
this is interesting, I am having similar but worse issues.
I was running the V&H Fuelpak and got the 0118 ET sensor code. I took it to the dealer, they said they tested the sensor it was fine, and it was my Fuelpak screwing things up. THey said they unplugged it and ran it, and had no codes.
BTW...running V&H Big Shots & SE Heavy Breather.
so of course they try to sell me the HD download. I did some research and settled on the PV from Fuel Moto. I loaded the tune and ran it for about 2 days, and the engine sensor code came back. So I loaded the stock tune, and it went it to Limp Mode, threw about 10 or 12 codes including the ET Sensor, throttle sensor, twist grip sensor, etc...along with the codes the OP noted, the loss of serial data to ECM. the codes would NOT clear. I unhooked the battery for 2 hours, still wouldnt clear. I loaded the FM tune, same thing, reloaded stock tune, same thing. after sitting for 2 days, the codes cleared briefly, 100 ft out of my driveway and BAM limp mode and all the codes back.
The dealer refuses to work on it. saying these happened after the PV download so its corrupted. Several calls to FM and they insist its impossible for the download to corrupt the ECM. So now i have an appointment at another dealer.
Not sure if I should give them the whole story, or just say here's the codes, fix it.
I also have the extended warranty...the first dealer refuses to talk to HD about it saying it will void my warranty.
Old 09-02-2015, 05:32 PM
lp's Avatar
lp
lp is offline
Received 2,836 Likes on 1,596 Posts
Just to throw some more info into the mix, an ET sensor is High code pretty much means that the ECM is not reading the ET sensor because it is either Open, unplugged, or the wires to the ECM are off or broken.
ET Sensor Low usually means the sensor is shorted.
Since you have loss of serial data etc as well I would be looking at the the ECM connector.
BTW, loss of ET sensor to ECM will stall the bike every time...
Old 09-02-2015, 05:50 PM
Hausguy's Avatar
Hausguy
Hausguy is offline
On mine, the second shop wasn't able to reproduce the problem. It did happen again once for me and that was the end of it. I've now put on a couple thousand+ miles an no more issues. It just went away.
Have you ever tried cleaning the big connector behind the throttle body? Given all of your various codes you're getting, it's probably something like this, the connection to the ECM or the ECM itself. Let them figure it out.
Old 09-02-2015, 06:41 PM
IHC67's Avatar
IHC67
IHC67 is offline
I did check the throttle body connector and put dialectic grease on it. However I hadnt checked the ECM connector, but supposedly, the first dealer tried a new ECM and it was not fix. But if they didnt check the plug connector...
Quick Reply: Intermittent stalling and throwing codes
