Notices
After market shocks why lower than stock
Old 07-08-2015, 12:16 PM
CVORoadKing2013's Avatar
CVORoadKing2013
CVORoadKing2013 is offline
Default After market shocks why lower than stock
Can someone explain to me why several of the after market shocks all set lower than the stock height?
Wife is not happy with the ride of the premium shocks that came on the bike and asked me to look for something better.
I was looking at the Progressive 944 series and the Supershox both say they set lower than the stock height.
What are teh plus and minus of a lowered rear shock
Old 07-08-2015, 12:35 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,543 Likes on 2,700 Posts
2 reasons: 1) appearance (some people like the stance of a lowered bike) 2) shorter riders require their bike to be lowered.
Most shock companies provide you with a choice - stock or lowered. If you wanted a stock height Progressive, you'd go with 444s
Old 07-08-2015, 12:37 PM
JMC22's Avatar
JMC22
JMC22 is offline
Most stock shocks are 12", I actually went with 13" JRI rear shocks just for better ground clearance - also being 6'2", I can still stand flat footed
Old 07-08-2015, 12:49 PM
CVORoadKing2013
Well I am 6'3" with a 36" inseam do not need a lowered shock can touch the ground just fine.
So the Progressive 444 or the JRI what other options are out there?
Old 07-08-2015, 01:00 PM
Magnut1's Avatar
Magnut1
Magnut1 is online now
Received 1,717 Likes on 839 Posts
Stock Premium ride Hand adjustable shocks come in 13 inch like on CVO Ultra's from what I understand.
Old 07-08-2015, 01:02 PM
Keithhu's Avatar
Keithhu
Tons. Ohlins, Racetech, Ricor, Terry Cable, others.
Old 07-08-2015, 01:34 PM
skratch's Avatar
skratch
skratch is offline
Received 4,297 Likes on 2,506 Posts
they also come in 12'' versions.
Old 07-08-2015, 01:36 PM
CVORoadKing2013
what is standard on the RGS?
Old 07-08-2015, 02:51 PM
mongomark's Avatar
mongomark
mongomark is offline
I just recently added a set of 13.25" Ohlin #2 adjustables (dampening is adjustable) from Howard at Motorcycle Metal. I have about 800 miles on them and I'm amazed at the improvement in both the ride quality and control. I had a set of Works Steel Tracker which were far better than my original shocks but don't compare to the Ohlin's. Of course, the Ohlin's were custom built for me. Part of the process includes providing both my weight and the passengers weight, how often I ride 1 and 2 up, what type of rider I am and what am I looking for. Howard then chose the springs and set up the dampening valving to match the springs (an over simplification, I'm sure). After installing and adjusting the spring sag (which is critical for the best ride) and some experimenting with the sweep valve adjustment (dampening), the transformation was incredible. I can't see where buying off the shelf can compete.
Old 07-08-2015, 03:30 PM
skratch's Avatar
skratch
skratch is offline
12'' premium hand adjustable
Quick Reply: After market shocks why lower than stock
