2015 ultra limited 2 up and loaded suspension psi suggestion?
07-03-2015, 05:07 PM
i rented this thing and felt like it was bottoming out a bit on the ride home so with gear i feel like it will not ride great.
what is a goos rear suspension psi to run it at for two up and fully loaded?
07-03-2015, 05:33 PM
I run mine 2 up with 50psi...that is usually pretty good.
07-03-2015, 05:43 PM
GREAT! i'll look at what it's set at in a few.
07-03-2015, 05:48 PM
Dealer should have set it up for you. Hope you get it right and enjoy the ride.
07-03-2015, 07:46 PM
Quote:
Originally Posted by
mikelikesbikes
the time wasn't even set....
07-03-2015, 08:02 PM
For the wife and I, 46 lbs is perfect, depends on your combined weights and gear
07-03-2015, 08:11 PM
well took the side bag off and hooked up the HD pump (borrowed from friend) and the pressure read zero. there was no air in the shocks at all. which is why it bottomed out and tore like crap. i pumped up to 40 and will give that a shot tomorrow.
07-03-2015, 08:19 PM
07-03-2015, 09:34 PM
With gear and wife, 45 lb-psi works best
