Different Tires
Old 07-01-2015, 03:27 PM
mandd71974's Avatar
mandd71974
mandd71974 is offline
Question Different Tires
Does it really make that much of a difference by having a different tread pattern on the front vs back. Thanks
Old 07-01-2015, 03:45 PM
leon anthony's Avatar
leon anthony
leon anthony is offline
there is front tread and there is back tread they are all different
Old 07-01-2015, 03:57 PM
mandd71974's Avatar
mandd71974
I should have asked...different tire manufacturers front & rear.
Old 07-01-2015, 04:44 PM
69cj's Avatar
69cj
69cj is offline
I have a Michelin on the front and Dunlop on the rear and it has been no problem at all.
Old 07-01-2015, 04:51 PM
Tired's Avatar
Tired
Tired is offline
Received 4,820 Likes on 1,762 Posts
As long as you don't tell either one about the other they will never know.
Old 07-01-2015, 05:50 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
For the type of riding we do ... doubtful. If you were road racing ... probably.
Old 07-01-2015, 06:21 PM
Red's Avatar
Red
Red is offline
You would never know they were different if you didn't look. I've never had a issue!
Old 07-01-2015, 06:50 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
No. I've done it before and never had a problem.
Old 07-01-2015, 10:14 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,530 Likes on 1,425 Posts
Might be OK, but is generally not advised.
Old 07-02-2015, 06:43 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
In half a million miles there have been a couple of occasions when mixed brands have not worked well together for me, but that was a long time ago. If you have changed one tyre and find the bike doesn't handle to your liking then change the other one to the same brand. Be aware that not all aftermarket brands use stock air pressures, so check the website for correct recommended pressures.
Quick Reply: Different Tires
