Help with Accessory Plug on Ultra Limited
I am trying to use the accessory switch on the dashboard of my 2013 Ultra Limited. The plug I was sold by my local HD is in the photo. I can't find a female plug under the seat or in front of the battery to plug it in. I did find a gray colored plug in front of the battery with a rubber cover but it is totally different. Have I just not found the right plug or was I given the wrong accessory plug. I posted this in electrical but didn't get a response, I don't mean to be impatient but I have my bike tore down and want to put it back together.
Bill
Bill
I just put a charging port in the tour pak of mine last week and I had to dig to find the accessory plug under the seat in front of the battery. There was 2 or 3 connectors in front of the battery including the accessory plug, it had a rubber plug plugged into the end of it. It was kinda buried, so keep digging around and maybe use a flashlight, it should be there. Unless there is something plugged into it already, then you would have to unplug it so you can use your splitter. Good luck.
mesquite
05-03-2013 10:17 AM
