View Poll Results: A poll
Voters: 214. You may not vote on this poll
Stopping with Front brake or Rear brake?
#31
#32
RE: Stopping with Front brake or Rear brake?
ORIGINAL: Detro996
Front break is where the stopping power is and its best to rely on it nearly 100% with the back brake being when you need a little extra or need to make the stop smoother. I use itmy mainly with my wife aboard so I can stop just a little smoother. Make the front the primary habit forming part of your braking. Can't tell you how many bikes I've seen that have run off the road trying to stop or slow downand there isan 8 foot black mark from where the rear tired was skidding. Bottom line don't rely on your rear brake to stop, especially in a panic situations.
What happens when you stop? Weight transfers to the front of your bike...if you're using your rear brake, your weight transfer is working AGAINST your stopping power. Front brake has more than 90% of your stopping ability. Most high side crashes also occur from people being caught off guard and end up locking up the rear tire...panic, and let off the brake which throws you high side. If you ever lock up the rear at speed you need to ride it out. Worst thing you can do is panic and jump off the brake.
MSF also teaches to use the front 90% of the way and add in a little rear if any.
Friend of mine rides a Triump w/a group of enthusiasts. Says many of them adjust their rear pedal so far down that even if you do use the rear, it's so low below the footpeg that you can't "over apply" it. Many take it off or set it down so far that you can't use it.
#33
#34
#35
ORIGINAL: zenmachine
I use both. Front and Rear Brakes (left foot down) then when stopped I put the right foot down so both feet are on the road. I think I picked that up in a MSF class?
#36
#37
#38
ORIGINAL: turbo38sfi
Use 'em both -- that's why they're there.
The oft-quoted "the front brake has 70% of your stopping power." Is based on the premise the bike is traveling fast enough that front-to-back weight transfer removes 20% of the rear wheel's "traction budget." At slow speed there just isn't that much transfer and the traction budget for the rear wheel is pretty high. At parking lot speeds rear brake is a good choice because a front wheel skid will take you down. (Off road experience doesn't apply here because pavement is stickier than dirt.)
