FatCat Slips WTF!
FatCat Slips WTF!
For the third time in as many good rides, I've had to loosen the bolts on the muffler and retighten them in hopes that they will stay put and after todays ride. No luck.
I'm at the point were I'm sure the bolts are right ready to break and the damned thing just will not stay put.
It's as if the flange on the header is tapered to the back of the bike and the muffler moves about an inch back in a few hundred miles.
Any help would of coarse be appreciated.
RE: FatCat Slips WTF!
I had the exact same problem. I was talking to D&D about an issue with ghost pipe and asked them if they were having the slipping problem with the exhaust side. Was told that a few woulddo it but most dont. They said they thought it had to do with the two mating pieces being too smooth. Suggested trying hi-temp silicone on the pipe before sliding on. That did the trick. Would imagine any type skuffing on one of the two mating surface would work.
I am sure you are aware that the allen head is metric. Use a 3/8" drive rachet and tighten the snot out of the clamp. Your not going to break that clamp, it is an aircraft stainless steel clamp. The worst thing that can happen is you break the screw and you will have to find another at a hardware store.
ORIGINAL: Electra Geezer
