Primarry oil
06-22-2015, 10:13 AM
Primarry oil
Can I use the same oil in the primarry case that I use in gear box?
06-22-2015, 10:22 AM
As long as its Amsoil..........lol What are you using in the gear box?
06-22-2015, 10:32 AM
HD synthetic will work in all three holes.
06-22-2015, 10:37 AM
Here you go.
06-22-2015, 11:22 AM
Mobil 1 Synthetic will also do in all 3 holes.
06-22-2015, 12:13 PM
Primary Oil
Your clutch is in there...How slick do you want it to be ? I stick with Formula +.
06-22-2015, 01:42 PM
06-23-2015, 07:08 AM
What is the problem with primary chain oil. This is recommended by the people that designed and built your motorcycle.
06-23-2015, 07:15 AM
Originally Posted by
47Norton
No problem other than cost.
You can spend $4 a qt or $15!
06-23-2015, 09:30 AM
1flhtk4me
What $4. per qt. oil/fluid are you recommending?
