PCIII and Security System
Brand new to the forum. Therefore, hopefully I'm allowed at least one dumb question. Just bought an '07 Ultra.I'm adding the HD SmartSecurity System after the fact (i.e. did not get it installed by dealer when I bought the bike). Also, planning on doing a Stage I upgrade with SE A/C, V&H pipes and a PCIII. Since (as I understand it) the PCIII "piggybacks" on your Fuel Control Module, and the Security system works (again as I understand it) by disabling your fuel module, is there going to be a problem when I add both the Security system and the PCIII? Thanks.
RE: PCIII and Security System
Before buying the security module from MoCo, you might check out Digitalguarddawg.com It appears to be very similar and very simple to install. It is on my wish list. Unless someone knows why I shouldn't. Or has one and has any comment on it I should know about?
ORIGINAL: pointswhat
Not sure but I think the Security system needs to be installed by the dealer. Someting with the buttonless fob being programed to the module. I would do a search here on the forum about it.
I also have a PCIII on my RK. I mounted it on top of the ECM and havn't had a bit of problems. I did both the siren and the PCIII at the same time. Good luck on your install.
