How often do you change...????
Old 06-18-2015, 09:08 PM
giacomo56's Avatar
giacomo56
giacomo56 is offline
Default How often do you change...????
I don't have a service manual...therefore, thank you for the answers.
How often (what mileage) do you change the primary oil? Or what does the book say?
How often (what mileasge) do you change the tranny oil? Or what does the book say?
Engine oil ... I change every 3000-4000 miles
This is not what oil you use, I don't need that info and I don't want to start anything ....
Old 06-18-2015, 09:11 PM
IzzoQuazzo's Avatar
IzzoQuazzo
IzzoQuazzo is offline
Retired Admin
Received 9,041 Likes on 3,711 Posts
You can download the Owner's Manual for your bike from the HD site. All the info you want is in there.
Old 06-18-2015, 09:18 PM
Buelligan666's Avatar
Buelligan666
Buelligan666 is online now
I recommend you buy a service manual. It's the best tool you can have in your toolbox.
Old 06-18-2015, 09:20 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
The owners manual says change the engine oil and filter every 5,000 miles, change the primary fluid every 10,000 miles and change the transmission fluid every 20,000 miles.
I do the engine every 5,000 and both the primary and transmission fluids every 10,000 miles.
Old 06-18-2015, 09:23 PM
Bikerscum's Avatar
Bikerscum
Bikerscum is offline
I once changed mine 4 times in an afternoon, I'm probably the wrong guy to ask.
Old 06-18-2015, 10:05 PM
capttawes's Avatar
capttawes
capttawes is offline
As posted earlier is the norm but I personally do oil at 5k with synthetics or semi and just do primary same time. Tranny I'm fine with 20k since I use redline. Everyone does what feels good for them and some more often.
Old 06-19-2015, 12:26 AM
Guntoter's Avatar
Guntoter
Guntoter is offline
Personally, I would recommend changing everything at the same time, everytime. I do and have not had any bearing or compensator trouble by doing this (so far.) Its only an extra 2 1/2 qts and will not hurt anything at all, only help.
Old 06-19-2015, 12:34 AM
giacomo56's Avatar
giacomo56
Thank you everyone, found the info in the HD web site, (thank you IzzoQuazzo) it says to change all of the fluids every time at 5K miles......damn i thought I could change the primary and tranny every other one.....it's expensive every time, buy hey it needs to be done.
Old 06-19-2015, 12:46 AM
FinalShot's Avatar
FinalShot
FinalShot is offline
Where did you read that? No HD manual I have ever seen says change all of them at 5000.
Old 06-19-2015, 01:32 AM
Buelligan666
I had to go check the Harley site to verify, but like I said earlier BUY A SERVICE MANUAL. The Harley site shows: engine oil every 5k miles, primary fluid every 10k miles, and transmission fluid every 20k miles. That is after the initial 1k service, which they show changing all. What site did you go to?
Harley maintenance schedule on Harley website
Quick Reply: How often do you change...????
