Right brake rotor very hot
I took the front wheel of my 12 Ultra off to take in and have a new tire put on. Removed the right caliper to get the wheel off. Everything seemed like it went together good. Torqued correctly. When I put the right caliper back on the mounting tabs didn't want to go underneath the mounting points on the fork tube. I had to push a little to get them in. Not much, but a little bit. Spin the wheel and it sounds like it's dragging. Again, not much. Wheel turns without much effort. Went for a short ride, and when I got home, the right rotor was VERY hot. Left was hot, but not near as hot as the right. Any ideas?
Thanks,
David
Thanks,
David
Be sure to report back...I've warped one rotor and have constant 'shhh' 'shh' noise of the pads touching...
I'm split both calipers and cleaned em right up...still does it.
David
any time I take the front off I put it back together and leave the nut and pinch bolts just barely snug. I get on the bike, pull in the front brake while bouncing the handle bars up and down. This gets everything in the correct position to tighten down.
It also could be the rotor as well. I went through a set on my 09.
Sounds like the wheel might be on backwards! If you put it on backwards when you spin the wheel the tab on the caliper will rub on the rotor and if you ride it will leave a nice gouge in it. Of course if you have ABS it is pretty hard to do that due to the bearings being different colors. I have seen it done numerous times.
Ride Safe,
David
G Funk
02-15-2008 07:23 AM
