V&H Power Duels vs. S&S Power Tune Duels
Which one and why? My first pick is V&H but after reading info on here in several threads about touching ground with them. Plus talking with my Dealership and them confirming that for aggressive riders. They suggested the S&S if that was something you would worry about.
Will be going with V&H Hi-Output slip-on this I do know for Road Glide Special.
Depends entirely on what system you have on your bike at the present time. If it's a free flowing header with a set of good resonators/mufflers in a dual configuration, no, you're good with out any further tuning. If you have a 2 into 2 system you'll need to re-tune it.
I have the S&S Power Tune Duals. They are a 2-1-2. simply a crossover tube. I had the shop install them when my motor was built. They were skeptical if they would make the power they were accustomed to. To be honest they were surprised at the power they made. See my signature below for power info.
I am extremely happy with this product.
Haven't dragged my V&H's and I think there design would be better flowing than the S&S which is just a balance tube. Granted the S&S do look to be a True Dual setup.
You might want to look into the HO slipons as you might wind up with to little back pressure unless you have a real hot 110"+ motor.
The Monster Rounds should flow more than enough for any 103-107"
I had the power duals on my 2010 Ultra and rode over 60,000 miles and never did I scrape the header or the cross over. On that bike I paired the header with CFR's. Dyno tune took care of any issues. On the 2015 Limited I went again with the power duals but installed the High Outputs in lieu of the CFR's. Yet to do the dyno but the stage 1 download has the bike running fine. Good fortune on your decision.
