Im adding a radio to my 2007 FLHTP. Can anyone direct me to a link or something to where I can find a ACC wire to hook up for Accessory Power wire. Thank you
if you just need power for the head unit (switched with ignition), there +/- can splice into Headlight - as previously said, HD provides a couple "empty" female spade connectors on the head light wires for this purpose. Later, when adding an amp, you will power that from the battery with possible remote input from radio to power up amp.
Is the wire on the headlight harness only ACC? And is the ACC wire on the radio, basically a switch telling the radio to turn on, because it already has a constant power?
Basically I want to be able to run my radio on ACC and not have the ignition on with headlights, pumps, etc
