Whirring Noise in Neutral
Old 06-17-2015 | 10:17 PM
vistavette's Avatar
vistavette
I had that same issue and read the thread jefla posted. Mine turned out to be the IPB, main shaft bearing, and the main shaft since the bearing went out and damaged it. Get it checked ASAP.
Old 06-18-2015 | 09:14 PM
mikeman54's Avatar
mikeman54
Sure is the IPB,and if you don't upgrade that compensator you'll be replacing many more times.
Old 06-18-2015 | 09:44 PM
lp's Avatar
lp
Interesting, haven't heard that one before.
The compensator usually takes out the starter.
A jacked up primary chain tensioner or an overly tight belt take out the IPB.
For those that don't know, the IPB is actually pretty easy to replace and under a hundred dollars or so to change (the bearing/race/seal).
It just takes a few special tools or you can use a few work arounds that work just as well. I've changed quite a few just using hand tools, a freezer, etc.
Also have never used a new primary gasket kit (lucky) but those are not all the much really so why take the chance if you're doing it yourself.
Old 06-18-2015 | 09:49 PM
rk10's Avatar
rk10
Thx for the info ....
Old 06-19-2015 | 10:18 AM
vistavette's Avatar
vistavette
Yeah; I did - or I should say the dealer did when the issues was fixed. While the SE compensator might help I'm not convinced that I wont have the issue again at some point. My repair was done at 45k and I now have 63k. We'll see as I get more miles.
SummitRK
07-07-2016 10:06 AM
Eunoterpsia
02-26-2016 07:39 AM
ofuzz_2000
10-06-2012 12:32 PM
GlassBikerNC
07-08-2012 11:13 AM
mbracey
08-10-2006 11:31 AM
Quick Reply: Whirring Noise in Neutral
