2012 street glide fender on a 2011 Electra Glide Ultra Classic
i put a Street Glide fender on my Road Glide Ultra las year. pretty much a direct swap except the wiring harness connector on the fender (which came with the light bar and harness) is different. I just went to the dealer and bought the other style connector. I changed the connector on the fender rahter than the one on the main harness. Really easy to do, you may need a wiring diagram although I think the colors match up.
I really like the style of the Street Glide fender and lights (no large center run/brake light. but i did add Custom Dynamic plasma rods and LED run/turn/brake bulbs. Next I am adding a TruFlex run/brake/turn to the Tour Pak as the RGU has no brake or turn on the Tour Pak. With your bike this should not be a problem though.
You can never have too much light on the back.
If you need a wiring diagram PM me with your email and I can send you a DropBox link with the info.
I like very much. Im guessing could do the same thing on the 14s?
I would believe so. Use an online parts finder to get part numbers for reference. Watch the classifieds for the parts, or order them from an online 20% discount retailer. If you have a body man you like, he could fill the holes and do the paint, unless you have the equipment and capability. I'm not familiar with who sells, or makes the new style bags aftermarket in CVO style. You'll have to research that part, or buy them from Harley. I did mine on the cheap. Good luck.
Ronnie's online parts finder
gvallanc
08-13-2012 02:48 PM
RE AND CHERYL
03-19-2011 10:33 PM
