Hot or Cold at oil changes ?
Hey Folks, The manual says to run bike to normal temperature before draining oil. Probably to thin the oil some for better drainage. Make since. In the back of my head I'm always thinking it would be better to drain it cold, after anything that may be in the oil has settled to the bottom.
Just curious what other riders think or do?
Received 1,633 Likes
I drain hot, then go in the house and get a bite to eat while it's draining.
plus if you do it hot and restart the bike afterwards there will be less time for the oil to drip off internal engine parts - before circulating oil fills the oil filter and pressurizes the system. since filter is sideways you cannot pre fill it and your system gets no oil until its filled
Received 49,832 Likes
