Exhaust heat question
The heat on my RKC was pretty unbearable after I put on my seat that pushed me down and back. So about a year ago, I changed out the headers to Jackpots 2-1-2 SS ceramic coated. That took care of the heat almost completely. Just took it in to the dealer to have the oil changed and the heat is suddenly back as bad as it was before. What happened?
.....could it be that it was cooler because it was spring....now that the hotter days are here it just gets hotter. nothing the dealer did in changing the oil should have done that. btw, cpt itch has some "crotch coolers" that go under your seat and help with the engine heat. take a peek at them. http://www.capt-itch.com/ i've used the same set for over 45000 miles on two different harleys. i just threw them over the stock shields and they work fine. not all the heat dissipates but it sure does help.
In your first post you state that you changed the header, in your second post you state that you had it changed. Do you know what else has been done to the bike?
SpringerRider
17
06-04-2019 05:30 PM
