handlebar swap...
RE: handlebar swap...
which ones ? I did the 508's on mine, stock cables worked but will eventually switch to longer braided cables, just make sure you splice in enough wire if you're running them through. I added 7 inches to my 508's to mine and had to start over again with at least 9". take your time and cover your fender with towels.
Hey Doc, I copied this post from another thread, hope it helps.
I just finished installing Wild 1 518's on my '06 RKC. I did it myself and could not be happier with them. The local Indie wanted $300-400 and the dealer wanted closer to $500. I started this project on Tuesday and finished final assembly early Friday morning(Tuesday and Thursday were half days at best). Overall I guess it at about 2 full days but you really need to take your time and get this right. I have to differ with one of the above posts that said you did not need to extend your wires. I didn't want to relocate the wire bundle as Wild 1 website recommends so I started with adding 4" to the right side and it worked but went with 6" for the left and I think it was a better fit. As far as cables go I went with Magnum Sterling Chromite II They seemed to have a much more user friendly website to purchase from (But to each thier own) and had the exact sizes I was looking for.I went with 2" longer on the throttle and idle, stock length for clutch and 2" longer for the front brakes. I got my bars from Zanottis, I was looking on their site and found tham for $160 in the Custom Chrome book but it would take my order so I phoned them and they said they were have probs with it and he actually gave me a better price of $151 for the 518's. I think total for just the bars and cables were $525 you can almost double that for labor if you have the dealer do it. It is really a pretty simple and straight forward job as long as you go slow and use your head. Oh, and the manual was invaluable as was HD Forums. Here is one of the most concise and helpful how tos that I have ever seen here on the Forum this guy Rocks https://www.hdforums.com/m_1328001/tm.htm. Hope this helps.
Jeff
Jeff
i was actually thinking about just doing a quick switch. no internal wiring, or extending, or braided cables etc. i will do that eventually, but i would like to make sure that i like the bars first. is it possible to just pull the old bars off, re-attach the controls to the new bars, and roll? i have the 518's.
ORIGINAL: dr.phatkins
ORIGINAL: Pastor John
Is your bike an '07 model? If so, you will probably need to add length to the wiring harness even if you route the electrics outside the bar. We had to add several inches when I installed the 508's on my '07 RK Classic. Are you using the 508's or the 518's?
i have the 518's which arent quite as long as the 508's as i understand it. directions say all original wiring will work, but u no how that goes.
