DIY air ride bottoming out
Hey guys, i installed a DIY air ride and for the most part i like it (slow fill rate, but can be fixed with tank) when i ride i run 90-100 psi and it seems pretty smooth if i hit a rough patch i bump the air up and it runs great. However ive noticed when i have the gf on the bike i have the air ran up to 130 and i still bottom out. Now before the obvious remarks, she is only a 103lbs , im surprised that 2 shocks designed for a car cannot carry a combined weight of 300 lbs, anyone else having similar issues?? Im running the blistein shocks and maybe they are worse than the monroes?? ive heard both ways so im not sure that the issue. Does anyone run a different shock other than those two?? Thanks in advance
use a screwdriver tip or something to push the center of the valve and see if it moves and if it releases air then you know that the lines and shocks are holding pressure
if nothing happens, remove the valve core and see if any pressure is released- if so, you know the system is holding air and that the valve may have been gummed up -
the valve is easily unscrewed with a tool from your bicycle patch kit
it could be that the lines or the shocks are blown out- this can happen even with a bicycle pump which is why they sell shock pumps
have a look and see if you discover the fault
mike
Try a different gauge. I have a couple that won't depress the valve core far enough to allow air to fill the gauge.
