Went from Ventilator to Chisel A/C. Right calf extreme heat
Have a 2010 ultra Limited. 110" D&D exhausts. Bought it with a SE Stage 1 A/C & when I upgraded the 103" to the 110" I put a 58mm TB SE Ventilator A/C. In the 4 years I've road this bike my right calf has been fine or normal. But recently I put the SE 58mm Chisel air cleaner setup on and OMG. It feels like I got a heat gun pointed at my right upper calf. Has anyone experienced this or a similar deal? I'm going to try a servo cover by Kuryakyn to see if it'll block some of the new found heat. If not I guess I'll go back to the ventilator. I'm going to remove the vents out my lowers & I do notice it's hard not to have my leg in direct contact with the cleaner since it sticks out so far but I get red burns on my calf in a long days ride. Just wondering if I'm missing a simple cure. I thought it might be my cooling fans pushing hot air across but turned them off. No difference
Bottom line is all was just peachy fine until I just had to have that cooler looking air cleaner. Lol
Thanks everyone
Thanks everyone
Received 75,225 Likes
I don't think fans are going to positively impact this particular issue. This is just an assumption but I would say the new air cleaner actually flows better, or at least flows differently, and has created a leaner AF condition, which will cause the EGT to get hotter; that might explain the hotter temp on your right leg. It would have to be hooked up to a sniffer to validate and possibly adjust the tune. Its been my experience that even changes as slight as cleaning the air filter will be reflected by different O2 levels in the exhaust, slight enrichment can lower EGTs by a few hundred degrees but it doesn't really cool the engine.
Received 2,529 Likes
Thanks Jason for your input. I've used your fans on my bike for a good while & they still work great. Because all was well before I changed out air cleaners & no other alterations were done. It's easy to assume the heat is from that change. I just haven't yet figured out what or where or how. I believe your words pretty much are right on. I'm going to try a few changes like the servo cover. Then take the lower vents off. Other than that I will probably put the ventilator back. But I agree it's not the cooling fans causing this focused heat flow
HD-it looks really hot with the chisel in my book. Mines the contrast black & 58mm as u mentioned. Your leg has to lean out a fair amount due to its width and it does get warm but that's not the heat I'm experiencing. I never liked the way the ventilator points downward a bit in the front but it's slimness is nice on the leg position. I'm gonna experiment this weekend & see if I can keep it on. It looks much more aggressive to me
