Electraglide Handle bars
Received 7,733 Likes
RE: Electraglide Handle bars
I used the Harley pull back bars. Added about 2" better reach. They make a big difference on comfort. Rather spendy when you are done. You must change throttle and idle cable, clutch cable and front brake line. It also is a fair amount of work pulling everything apart to do swap. Overall I would do it again. I looked at alot of bars before going with the Harley's. One plus with the Harley parts is you get nice braided stainless front brake lines. You may want to spend a little more and also go with braided cables. I am 5' 10" and the bars make a big difference.
[IMG]local://upfiles/1346/A7D8B4CC04064E219E620A641B74DD54.jpg[/IMG]
I don't think I ever did a full blown how to...
If you have a manual, you can do it. The only problem I had was with the clutch cable...they don't tell you to reroute it, and you need to reroute it inside the radio bracket.
The other thing is to make sure you get a pin puller...that way you don't have to solder all the wires back together with heat shrink.
After I put them on, I had to adjust the height one time...been happy ever since.
Mac
Mac
