Perfect thank you,
well now is there a secret on how to get the cover off?
Grip it pull each corner. Fuse box is under it. Got this is happening now. on the side of the road at night is a heck of a time to try and find the fuse panel.
I was having this same issue a couple months ago. It ended up being a bad pig tail on the bike side. Swapped it out for a new one and haven't had any more issues with it. I have 3 tenders I use for other stuff in the garage and I moved them all around and they were all working. That's how I figured out the harness on the bike was bad.
Harley battery tenders havve a 7.5 amp fuse in the harness under the seat. Check to see it’s in working order
