Why is my battery tender light yellow?
Old 07-03-2016, 10:16 PM
akodust's Avatar
akodust
akodust is offline
When mine stayed yellow last month, one of the cells in the battery was gone. So I got another battery...problem solved.
Old 07-04-2016, 03:06 PM
Tactical111's Avatar
Tactical111
Tactical111 is offline
Thumbs up
Originally Posted by Cpl Ed
My battery tender/charger has 6 and 12 volt options. (Deltran). If it charges at the 6v setting it will show yellow for, in my case, ever. Figured it out the next day. Switched to 12v and it went green very quickly.
Hmm, that's interesting. Don't think my Diehard Bat Tender has that option but will double check now. Regular battery charger has a 3 and 6 amp choice on it but is all 12 volt I'm fairly sure.
Old 07-04-2016, 07:45 PM
Cpl Ed's Avatar
Cpl Ed
Cpl Ed is offline
Here is my Deltran
Old 07-05-2016, 02:01 AM
BlueBeast's Avatar
BlueBeast
BlueBeast is offline
I never knew the tender even had a yellow light, never saw it on mine in the past 11 yrs. Just the red for charging and green for the charged or float status. The charger for my cordless drill and flashlight has a yellow light and that means the battery is either toast or too hot to charge if you were just using it constantly.
Old 09-15-2020, 07:19 PM
don Gibson's Avatar
don Gibson
don Gibson is offline
1st Gear
Originally Posted by RANGER73
If the connections are good and it still doesn't turn green after a while check the in-line fuse.
where can I find the in-line fuse ?
Old 09-15-2020, 07:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,807 Likes on 4,756 Posts
You gotta tell us what the model and year of the bike is .....
Old 09-15-2020, 07:38 PM
don Gibson's Avatar
don Gibson
1st Gear
its a 2018 cvo limited
Old 09-15-2020, 07:42 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,112 Likes on 5,387 Posts
On an 2018 touring bike the fuse for the tender is in the fuse panel under left side cover. It is not in the cable like it was on other years. The tender cables became factory installed that way in 2017.
Old 09-15-2020, 07:50 PM
don Gibson's Avatar
don Gibson
1st Gear
Perfect thank you,
well now is there a secret on how to get the cover off?
Old 09-15-2020, 07:54 PM
Dynamick's Avatar
Dynamick
Dynamick is offline
Not a Moderator!
Received 6,976 Likes on 3,340 Posts
No secret, it just pulls straight off.
Quick Reply: Why is my battery tender light yellow?
