The KLUNK, and ATF in the primary, again.
#31
Thats exactly what my concern was with running ATF that i posted in a thread this same OP had on ATf someplace else with it being in fact thin visc wise (compaired to REC by mfg HD 80wt or 85wt or syn3 20-50 in prim ) not able to handle lube duty when it comes to larger bearings in prim case when ATF was designed mainly as a hyd lube and not to handle a lot of hi trq/pwr lubing for ex inner prim case bearing on the HD.
Stop with the unfounded opinions, and just post facts for once.
And, as a bonus question, what fluid do auto transmissions handling 500 hp, with needle bearings, roller bearings, clutch disks, gears in mesh use?
Scott, if you don't want to run ATF, trust me... no one cares. But you really should make an INFORMED decision instead of just waving the viscosity flag.
#32
While vehicles, trucks, heavy equipment, ets, do use ATF in transmissions or other mechanisms, I believe these will be circulated by a pump. Usually a high pressure one at that as most auto transmissions do. With the ATF being pumped at pressure it can lube much better than the splash or run down method in our primaries, which is why the early SE comps were not getting proper lubrication. ATF is basically hydraulic fluid with some lubrication properties.
#33
There are large bearings inside an automatic transmission, all lubricated with the ATF. Even more in a front wheel drive application, since a differential is included. These bearings are ball or roller depending on the manufacturer and are every bit as large or larger than the inner primary bearing.
#34
#35
maybe this will help
http://en.wikipedia.org/wiki/Motor_oil
#36
#37
That does sound the simplest, and I see no problem with it although I have never tried it. Mainly because I am a cheap SOB and don't believe in the V-Twin hype in any way. So that lets me run Mobile 1 15-50 in the engine (no reason for motorcycle specific). Most anything I have on the shelf in the primary (usually Rotella T). And now am trying amsoil 75-90 severe gear in the trans because of the good results someone I truly trust (my Son) told me it smoothed out his 5th gear compared to Mobile 1 Syn 75-90.
#38
Left right left right left......right WTH do I do. I'm all about preventative maintenance. From what I have read so far it sounds like the clunk is coming from the dogs. I would think if the dogs are stopping or separating something than the strength of the material used to machine the dogs is a little more relevant than the lubrication factor (lubrication still being a factor though). Thats the clunk.
As far as lubrication for the clutch, i'm lost lol. I was told by a 40+ year old guy working on bikes for years to run Synthetic 20W-50, 10W-40 in the primary and 75W-90 in the transmission. That is what i will try for now. He has ran it for 28K miles and my other co workers swear by it too so i will give it a try.
Great thread full of information!
#39
Actually I've tried it, the synthetic ATF works better. If it didn't, I wouldn't use it.
"It's your bike, put whatever the hell you want in it."
I do, and you should to.
#40
Don't ya know that if you are making an oil the smartest thing to do is "label" it V-Twin, then you can charge an extra 50% and everyone will think it's special stuff.
