Help to identify HD SE AC Filter
Maybe someone can help me identify the AC filter on my 2007 RK Custom.
The backing plate is the standard HD Screamin Eagle Stage 1 (HD# 29478-05A), but the filter is not HD stamped. The only marking is what appears to be an Arlen Ness logo. No other numbers or identification anywhere.
The previous owner said the HD service dept told him that the filter was a DRY type and to only wash the filter, but not to oil it. I am the 3rd owner, so I assume the original owner did the changes.
Can you verify if that is correct, or is this filter supposed to be oiled? Did Arlen Ness ever used to make dry filters for the HD SE AC?
I'm thinking its time to change to a K&N anyway because this one looks like a few holes are starting to appear.
Thanks for any help.
From the Arlen Ness site:
HAND MADE FILTER ELEMENT:
Each filter is handmade in the U.S.A. one at a time using the finest materials available
Filters are available in red or stainless steel jacketed filter elements
Standard red filters are pre-oiled, washable and feature 4-layers of surgical grade cotton for optimum filtration and maximum airflow
Stainless steel jacketed filters feature a synthetic material that is water resistant and never needs to be oiled. Just wash and re-use
Unlike most other filters, our process of hand pouring each filter ensures a strong clean bond between filter element and body with no restrictive urethane residue on the filter element
I agree your best bet would be to replace the filter with a KN and get the recharge kit from KN (soap and oil).
You want this one: http://www.knfilters.com/search/prod...x?prod=HD-0818
Thanks so much. I looked all over the Ness site but never saw that. If you look for just replacement filters they don't tell you that. I had to go to the Big Sucker description to find what you posted.
I feel better that its not oiled, but gonna order an K&N soon.
If I hold it up to the light, this hole doesn't go completely through, but you can see it in the pic.
So is this a good filter to keep? Or should I switch to the K&N?
stagolee
10-30-2008 07:43 AM
