Primary oil amount?
Old 06-01-2015 | 10:53 AM
Vernal's Avatar
Vernal
Originally Posted by fwb35
Hey all, was my first time changing the fluids in my 2015 Ultra Classic Low,
I drained the primary and went to fill it, says 32 oz, I put almost a quart in and it starts spilling out, the bike was on the kick stand for the change, when I took off the derby cover nothing spilled out, when I drained it the fluid stopped coming out and I assumed it was empty. I also thought does this have anything to do with the Low model having a narrower primary cover? thanks
This is from the 2015 Service Manual:
Have a good trip.
Old 06-01-2015 | 11:02 AM
Roadie13's Avatar
Roadie13
Maybe they changed the definition of "wet" and "dry" for the Rushmore bikes, but in the past wet has meant just a straight fluid change - pull the drain plug (and filter for engine oil), replace drain plug/filter, and refill. Dry refers to doing the above and then pulling the primary cover to do additional work such as changing clutch plates or a compensator because additional fluid is lost when the cover and other components are removed - therefore more fluid required for a "dry" fluid change compared to a "wet" fluid change. It is not referring to a dry or wet clutch assembly.
Old 06-01-2015 | 11:04 AM
KCFLHRC's Avatar
KCFLHRC
I would suspect step #9 got skipped
Old 06-01-2015 | 11:07 AM
472viper's Avatar
472viper
yeah that.
Old 06-01-2015 | 12:01 PM
fwb35's Avatar
fwb35
I stand corrected, 38oz, but still, if I took the cover off before I drained it and nothing spilled out why would it when I was filling it?
Old 06-01-2015 | 12:13 PM
Jackie Paper's Avatar
Jackie Paper
I would be very concerned you drained the wrong hole if 32 oz spills out. I know you know how and maybe it's just different. It takes 1 extra qt above the proper amount to get mine even with the top edge when level (son thought that was level and we were using SYN3 then). I also think when Harley from 32 to 38 was to help the compensator since it's at a higher level in a 38 bike (over the spring) then in a 32 (under the spring) on the clutch ..
Old 06-01-2015 | 12:30 PM
Vernal's Avatar
Vernal
The only logical answer is there wasn't the correct amount of oil in the primary when you took the cover off.
Was this the 1k service?
Old 06-01-2015 | 12:47 PM
fwb35's Avatar
fwb35
I have been servicing my own bikes for years now, it was the correct drain plug, the bike was leaning on the jiffy stand when I took the derby cover off, no fluid spilled out, I have always done it this way on my 1999 FLHT.
My 1,000 service was done at the dealer, they told me it was mandatory I have it done at the dealer, $310, I have driven the bike almost 2,000 miles since that service and wanted to change all the fluids before my trip, will be about 2,500 miles total.
Old 06-01-2015 | 12:54 PM
KCFLHRC's Avatar
KCFLHRC
They lied to you
M Oclaf (09-12-2022)
Old 06-01-2015 | 01:01 PM
fwb35's Avatar
fwb35
They lied to you
Would not be the first time a HD dealer lied to me.....
Quick Reply: Primary oil amount?
