rear fender fascia on electra glide
i really want to put this rear fascia, or as harley calls it ground effects, on my 2001 police electraglide. im wondering if it will work with the fender i have. since i have a different light im not sure it will work. not even sure if the sides of fender are the same. if someone would let me know if this will work id appreciate it.
You will also need to get the fender to saddleback support bracket, the support plate for the fascia., and the rubber grommets and possible the hole fillers if you are not using qd tour pac hardware And the Tri bar light if you choose to run one. I added my light after these pics were taken. I bought a bikers choice one that works as a brake light too.
I filled my holes from the back with a fibre glass backing and Bondo on top to get everything smoothed out.
zeus33
01-17-2012 04:38 PM
