Has anyone put a CVO rear fender for a 2013 or earlier on a 2014 or newer bagger? Accordingly to the Harley catalog it does not fit 2014 or newer. If not, what is different aside from the saddlebags?
The Harley parts catalog shows the old style for 2013 and earlier and the new (uglier in my opinion) version for 2014 and up. So it would seem that anyone whom is capable of a little wiring would be able to make this work.
I know you can use and earlier fender on the standard ones, while the fender itself will bolt up, there may be issues with the fascia and the new style saddlebag supports.
I have the CVO Topshop minister on my 14. It worked but took some modification. The fender fits no problem but the back bottom portion of the CVO lights interfere with the saddlebag bracket supports. I also had to rewire and change the plug to fit the 14, that part was simple.
